By R30 Guru
I had to remove the original radiator support panel & replace it with 1 out of a shell I wrecked as previous:crazy:owner had butchered it with a disc grinder and cutoff wheel to fit the dodgey intercooler piping.
By R30 Guru
Had to removed the whole front end assembly to replace front crossmember and straighten the lefthand chassis rail & while im at it I will replace the stock crossmember with one from a DR30 which will move the engine and gearbox back 25mm this may not sound like much, but this is stage 1 of the frontend rebuild
stage two will involve replacing the steering box and arms with s14 front hubs reversed so that the steering arms face the front and fitting a powersteering rack from a Nissan Serena so that I will then be able to run a rear sump which will inturn tranfer a bit more weight to the centre of the car.
As far as the interior is conserned still under development throwing a few ideas around.
I was planning on using these seats but have changed my mind now
As far as the engine goes, I haven't done much with that as yet.
Just trying my spin on an
By R30 Guru
Am also working an
Here's a few pic showing what ive done so far!
