2x ca18 injector ballast resistor wtb
skdmrx
Post by skdmrx »
As per title.I'm using ca18 injectors on the VH41 so i need two of them
datsunboy
aka: Dan
Re: 2x ca18 injector ballast resistor wtb
Post by datsunboy »
see what else you can find John.....I reckon most Nissan ones will be the same.
Tho I have only tested a E15ET one, and it is the same as the CA18DET one
skdmrx
Post by skdmrx »
other option is something like this
http://www.trademe.co.nz/motors/car-par ... 033578.htm
I just need to find out what resistors theyre using.Anyone know?
datsunboy
aka: Dan
Post by datsunboy »
I'll see if I can find out the specs of the CA18 resistors in my FSM for you.......If I can find the specs, then I could make you one of those ^^^
skdmrx
Post by skdmrx »
bloody fantastic :highfive:
DJZ
Post by DJZ »
I'm looking for resistors for my car too, I found some like the ones they are using on http://nz.element14.com/resistors
Pretty pricey though if you need lots of them.
L28s have them factory, from memory they have two "packs" screwed together, one for 4 injectors and the other for 2.
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
datsunboy
aka: Dan
Post by datsunboy »
right John!
I found out what ones we need, and I can get them for $3.80 each (best to get 8 of them for you so all resistors are exactly the same)
skdmrx
Post by skdmrx »
bloody fantastic.
