Iv got the cog now i need the wee tab bolt that holds it in.
Andy
Ca18 gearbox speedo drive tab bolt.
Re: Ca18 gearbox speedo drive.
Electronic or cable? Do you need a particular gear if it's cable?
Cable, any ratio will do not to fussed thanks.
I think I've got some spares, I'll have a look tomorrow night if I remember.
I found a white cog one and a purple cog one, all yours if you want one. Text me on 021 161 8827.
Re: Ca18 gearbox speedo drive tab bolt.
I found one but it's attached to a gearbox, it would take about 5 minutes to make one? A washer with one side flattened off would prob work too.
Made one sorted!
Speedo is not working so i think I need a longer speedo drive gearbox cog anyone got a standard ca18det one?
datsunboy
- aka: Dan
a standard ca18 speedo cog is an electronic one so wont be of any use to you
