Z18ET Help
- datrat
- aka: Luke
Z18ET Help
Anybody know Z18ET engines well enough to come give me a hand... I have a rebuilt engine which runs ok but lacks alot of power it has good compression etc just want someone who knows them to help me a bit in exchange for beer or cash or whatever...
- aka: J
Re: Z18ET Help
timed right? clean injectors? clean air filter? what are the compresions?
- aka: Dan
Re: Z18ET Help
how much down on power?
sounds like it could probably be your cam timing?
- datrat
- aka: Luke
Re: Z18ET Help
yeah looked at cam timing and I'm pretty sure I might be out a tooth but would love for someone to confirm this before I change anything... are you keen to take a look I am not that familiar with these engines and the book is very vauge on info
- aka: Dan
Re: Z18ET Help
Is it driveable?
When I built my first L20b, I had it 1 tooth out on cam timing, and you'd be suprised how much difference it makes!
It's kinda hard to check the cam timiming 100% with the front timing cover on, as you need to line up a little mark on the crank......but if you can get it as close to TDC as you can, then you should be able to see if your out or not on timing.
- datrat
- aka: Luke
Re: Z18ET Help
thanks mate yep sure enough 1 tooth out... I managed to use pry bars, welding wire, cableties etc and changed it one tooth on the cam without removing the front cover it now runs as it should... plenty of power to the point it will spin the the wheels in second when it comes on boost... stoked
- aka: Dan
Re: Z18ET Help
sweet, good on ya!
You'll be able to bring it to the NZ Datsun Nationals at Akaroa on Labour weekend then!
- aka: The shed
Re: Z18ET Help
nice job! what mods have you done to your z18? how much boost are you running?
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1972 1200 coupe z18et
1979 Starlet Bugeye
1974 ke25 coupe
- datrat
- aka: Luke
Re: Z18ET Help
Its a rebuilt Z20E engine standard internals with the Z18ET turbo gear on it running factory boost which if the gauge is correct about 7z18et1200coupe wrote:nice job! what mods have you done to your z18? how much boost are you running?
- datrat
- aka: Luke
Re: Z18ET Help
datsunboy wrote:sweet, good on ya!
I'm trying my best to get it all sorted... still have full exterior panel and paint and compliance to get which may be a bit tricky considering it has aftermarket seats, modified engine, and its lowered... do you have to get it certed before or after compliance???
