1200/B110 Tacho/rev counter...... Some plonker has rubbed out the factory numbers/marks with what looks to be black paint with a brush and put on new numbers/marks....... Never tested and WONT be sold with the plastic cover show in the photo, but with the STD flat plastic cover. $75ono
1200/B110 SSS Grill badge........ Could also be used on a 1600........ Not mint, abit of the chrome has come off on the top edge. Both mounting bits are there, no nuts or backing plate thing. $75ono
120Y/B210 Bits.......... No pictures, if you want some just ask.....
Gauge clusters $free to a good home. About 4 of them. None are tested.
Passenger side parcel trays $10 each. Have 3 of them. All are in pretty good nic.
Tacho/rev counters. Have 2 or 3 of them. None are tested. $75ono each.
Wagon tail light lense's. Brand new aftermaket ones. $100ono
Plus the odd bit sitting around here, like badges and small interior bits. Im sure there is more........
CA 18 DE Gearboxes....... Have 2 of them, 1 of them(So I was told) has had new bearings and in pretty good condition, but Ive never tested it. Comes with a gearbox cross member to suit a Sunny/B310. Gear lever. $100ono
The other one is unknown condition. Has a gear lever(held in by a piece of brake tude) $50ono.
CA18 Starter motor, unknown condition. $20ono
CA18DET STD Cast Exhaust manifold. $50ono
Drive shaft with yoke to suit the DE boxes, with a flange to suit what looks like to me a H145 diff head. Came out of a Sunny/B310. Has been balanced. $100ono
CA18DE/DET flywheel. Getting machined up. $120ono
Clutch master and slave to suit the boxes. Never tested. $40ono
180B/610 SSS Badge......... Its ruff. With a good tidy up/repaint would look mint as. $50ono
