Z18ET Headache !
datman310
Z18ET Headache !
Post by datman310 »
I'm looking for some help / to be pointed in the right direction, I have not alot of experience with EFI, used to carbs and points, anyway the Z18ET in my bluebird seems to have a issue when you put your foot down it just coughs and splutters. it starts fine and if driven softly will run fine. I have checked the AFM seems to be working. plugs look ok coils are new-ish GT40's.
timings correct and was going awesome when i first got it. but seems to have developed this wee issue that seems to be intermittent
could it be fuel pump or computer? I have another motor im getting soon will try swapping computers over see what happens then
Can anyone shed some light on my issue?
z18et1200coupe
Datsun Driver
aka: The shed
Re: Z18ET Headace !
Post by z18et1200coupe »
are you SUPER sure its not your afm? have you tried disconnecting it and taking it for a thrash? it runs like absolute crap until you hit boost, then it should run rich as, but not cough or splutter once in boost
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1972 1200 coupe z18et
85_Z31
Re: Z18ET Headace !
Post by 85_Z31 »
You might need to try another Crank Angle Sensor or another Ignition Module after the AFM these are the next most likely to go bad.
Steve , My Nissan Z manual has a few testing procedures for some of these electronics, although different models the electronics are of a simialr type and age
So if your keen to give it a nudge with the multi meter just let me know and we can take a look this weekend.
datman310
Re: Z18ET Headace !
Post by datman310 »
I tried taking the plug off the AFM and it just wont budge it feels like its gunna break off, mind you i can be a bit of an ape when it comes to that kind of thing maybe there's a trick to it and yea James it definitely sounds like a plan as A: i dont know bugger all about this kind of stuff and B: I'm trying to get it to run properly so you can drive it for akaroa
85_Z31
Re: Z18ET Headace !
Post by 85_Z31 »
No worries dude, I will roll up on Sunday with the book and Multi meter !
datman310
Re: Z18ET Headace !
Post by datman310 »
sounds good! Bring petrol a rag and a lighter as plan B haha
datrat
aka: Luke
Re: Z18ET Headace !
Post by datrat »
datman310 wrote:I tried taking the plug off the AFM and it just wont budge it feels like its gunna break off, mind you i can be a bit of an ape when it comes to that kind of thing maybe there's a trick to it and yea James it definitely sounds like a plan as A: i dont know bugger all about this kind of stuff and B: I'm trying to get it to run properly so you can drive it for akaroa
Hey mate the AFM plug has a spring wire plug set up... you have to pry the spring clip outwards on both ends of the clip for it to release
z18et1200coupe
Datsun Driver
aka: The shed
Re: Z18ET Headache !
yeah get a flat head screw driver onto the little metal band that clips around the AFM plug and just flick it off.
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
broke
aka: John
Post by broke »
Bags lighting the rag if you decide to go that route, just let me strip all the suspension, brakes and driveline out first.
datman310
Post by datman310 »
:guns: NO DEAL
