so iv almost finished the sr20de for my 1200 ute, iv got a sr20 bellhousing i was going to go with a sr20 or a stumpy L-series gearbox but i have now decided to fit a bench seat in the ute and make it columnshift manual so i something else is there any model datsun that runs a manual columnshift behind a L-series engine? or something else that will easily be modified to work
cheers
what gearbox to run
- Evil13
- aka: kane
what gearbox to run
1200 sedan
1961 ford galaxie
1961 ford galaxie
DAT620
- aka: J
Re: what gearbox to run
Pink Parrot auto wreck here in chch had a D21 with a L and column shift... they still might have it
I talked to a dude the other day that had a column shift gearbox from a 430 Cedric that had an L20ET.
nick_m
nissan serena vans came out with sr20s and column shift., Try track down one of there gearboxes and it should be a straight bolt up affair i would think
- Evil13
- aka: kane
I can only find 4wd boxes can you just take off transfercase and put a 2wd housing on
1200 sedan
1961 ford galaxie
1961 ford galaxie
nick_m
not sure. You would have to have a good look at the gearbox and see if it looks doable
- Evil13
- aka: kane
Found myself a gearbox from a Serena cheers for the help
1200 sedan
1961 ford galaxie
1961 ford galaxie
nick_m
choice dude, keep us updated on how you get on
