Hi Guys
I need a set of Steel Coilover Sleeves, New ones are $179 but I Figured I would check here in case somebody has some that they are not using hidden away.
Needs to fit 2.5 Coil overs, Diameter ( ie 52 or 55 ) is not so important as they are not actually going on front struts.
I don't want to pay the moon In case my idea don't work either.
Jimmy
WTB Steel Coilover Sleeves
Re: WTB Steel Coilover Sleeves
Where did you price those up at James??? My sleeves were $30 each from stocks, but wasnt including the aluminium nuts that go with them.
179 is Jamex
Inc 2 sleeves, Alloy spring nuts + Lock nuts and Top Caps
But $30 Each from stocks sounds a hell of a lot more like it, I will give them a call tomorrow
if you dont have any luck james, flick me a txt, ive got some sleeves and nuts lying around you can obtain
- illusive
- aka: Chris
if he has already sourced some, im in need of some for my r31 struts.
Give us a yodel if he has cheers
You Sir Have PMdirtyleppa wrote:if you dont have any luck james, flick me a txt, ive got some sleeves and nuts lying around you can obtain
