WTB Steel Coilover Sleeves
Posted: Wed Mar 28, 2012 12:45 pm
by 85_Z31
Hi Guys
I need a set of Steel Coilover Sleeves, New ones are $179 but I Figured I would check here in case somebody has some that they are not using hidden away.
Needs to fit 2.5 Coil overs, Diameter ( ie 52 or 55 ) is not so important as they are not actually going on front struts.
I don't want to pay the moon In case my idea don't work either.
Jimmy
Re: WTB Steel Coilover Sleeves
Posted: Wed Mar 28, 2012 4:51 pm
Where did you price those up at James??? My sleeves were $30 each from stocks, but wasnt including the aluminium nuts that go with them.
Posted: Wed Mar 28, 2012 5:35 pm
by 85_Z31
179 is Jamex
Inc 2 sleeves, Alloy spring nuts + Lock nuts and Top Caps
But $30 Each from stocks sounds a hell of a lot more like it, I will give them a call tomorrow
Posted: Tue Apr 03, 2012 4:54 pm
by dirtyleppa
if you dont have any luck james, flick me a txt, ive got some sleeves and nuts lying around you can obtain
Posted: Tue Apr 03, 2012 5:12 pm
by illusive
if he has already sourced some, im in need of some for my r31 struts.
Give us a yodel if he has cheers
Posted: Tue Apr 03, 2012 5:28 pm
by 85_Z31
dirtyleppa wrote:if you dont have any luck james, flick me a txt, ive got some sleeves and nuts lying around you can obtain
You Sir Have PM
