hi friends I'm Claudio I'm from Portugal 25 years, I have a 1600 Datsun 1970 and I am applying ca18det the engine, I have some problems in finalizing the electrical part to get to work, if anyone can help I would appreciate... thank you all ...
Subaru LSd's can be made to fit.
Or you could go down the path of fitting an R200, and having later model CV type axles from the likes of an r32 skyline etc shortened to fit. Then you can run a viscous lsd from a skyline or similar. Or fit an aftermarket clutch lsd.
Without knowing what the supply of parts cars is like in portugal, it's hard to say what you might use.
Bartman wrote:Subaru LSd's can be made to fit.
If I get a differential of a subaru, you can use the same transmissions of datsun 1600??
