datsun 1200 radiator brand new core and repainted 6 months ago only been filled with antifreeze never been used
250 ono
pm me or txt
recored datsun 1200 radiator
Re: recored datsun 1200 radiator
Have you got some pics?
datsun118
- aka: .
will put some up tomorrow
datsun118
- aka: .
photos of radiator and yes it comes with new fan
yeah would have been keen as - but looks like you have sold the setup now?
datsun118
- aka: .
yes kitch have now sold the radiator to make way for a custom alloy one
how much the custom alloy one stinging you?
that's ideally the path I want to take, be keen to see what you end up with, or
would be keen to maybe get some discount deal if the manufacturer was to make two at once?
I want one similiar to factory but in alloy, I want hose connections etc as per factory, and
as have no space to my crank wheel, I have to go to a push fan setup (similiar to the one
you had advertised)
you had advertised)
unlimitedpower
- Datsun Mad
Civic radiator be about that size go for one of thoes they seem to have no problem cooling big power hondas and evos down.
All depends if you want the look of the alloy radiator though cos im thinking of getting one mainly for that reason.
Has anyone tried one of these?:
http://www.trademe.co.nz/motors/car-par ... 726975.htm" onclick="window.open(this.href);return false;
Not bad buying and look tidy enough.
I am assuming custom radiatior will be $450-600?
Problem with the chinese alloy civic radiators, is they look a bit cheap and nasty IMO, and also the outlest arent in the exact same position. (I want factory locations of pipes etc to suit my BProject Silicon hoses).
datsun118
- aka: .
ended up getting one of these the are a good radiator only had to slot the mounting holes because my rad support has been repaired great radiator tho kitch for the price i will put some pics up soonKitch wrote:Has anyone tried one of these?:
