please remove/sorted
joelbrown
aka: Joel
Post by joelbrown »
Am after a stainless (consider plastic) grille n round lights n surrounds to replace my current square headlight and plastic grille setup (bakkie style) .swaps considered. Cheers
1990 1200 ute
joelbrown
aka: Joel
Re: WTB:1200 grille & round headlights. or swaps 4 bakkie st
Post by joelbrown »
I wanna end up with this kinda look
1990 1200 ute
project_1200_ute
Datsun Dreamer
Post by project_1200_ute »
ive got a couple ute plastic grills if u get stuck i know what u mean though the sedan steel ones are way better i changed mine too
Blair
Post by Blair »
The plastic grill and the metal grill have different mounting points on them. Ive got pictures some where, I'll try and dig them out........
joelbrown
aka: Joel
Post by joelbrown »
Thanks man, info on mounting points wud b handy. Does it include mount points/bracket setup for swap frm sq to rnd headlights 2?
1990 1200 ute
jas1200
Datsun Driver
aka: Jas
Post by jas1200 »
Like your plan, its not that hard to make up brackets for the grill, not sure about the headlights.
joelbrown
aka: Joel
Post by joelbrown »
Thanks man. Am stoked at the moment, i finally got evrythng finalised- the ute is locked in to get panel n paint job on friday! Am deleting all tie hooks and clips and rear bumpers for a smoother look. 8-)
1990 1200 ute
jas1200
Datsun Driver
aka: Jas
Post by jas1200 »
You should able to get the grill and the rest of the bits you need by asking around and keeping an eye on trademe, I have the parts you need but want them for my own project. Are you going to put a crome bumper on it aswell?
Ifg you are getting P&P this Friday you want to get the brackets done at the same time, come and have a look at the brackets on my sedan if you want. Numbers on here.
woodies72coupe
Post by woodies72coupe »
I've got some bits that will probably work. You are more thanks welcome to give me a call and pop over to have a look.
