2x Coilover Top Hats , Stainless steel to suit 2.5 Race spring - 20mm Inner dia hole for the shock piston shaft, test fitted only as new conditon. $30 ---Mark 105 has first call on these
New Stuff Listed 26-08-12
Nissan Z31 Universal Steering shaft , seems to be in good condition - splines not damaged
Could be useful for somebody doing something quite custom - see pic $50
Nissan Z31 Rear hub 4 Bolt CV Flanges. These came from a set of hubs that are long gone, good for converting to CV rear end for your R200??
bit dirty bit good condition and hard to find on their own $70
Nissan Z31 Big Single Pot Front Brakes, these have the later style bolt spacing same as the Nissan 4 pots ect. Calipers will need a rebuild kit and are missing the metal brake pad clips and shims, they do include the Banjo bolt . $40 ? these suit a 20mm Rotor
Nissan 54mm Throttle Body, same bolt patten as most Nissan EFI Stuff, not much use to me, takes a normal Nissan TPS sensor ( not included )
And this next item is an inquiry of Interest type thing.
I could Sell a set of Z31 Front struts that have the factory oil shocks still with them ( could be rebuilt using Steves method )
With these shocks I could include King lowering springs that have only done 5000km and cost me $250 .
I also have a set of aftermarket GLAND nuts that would allow you to fit a aftermarket GAS shock insert.
These have the 54mm bodies and are not as easy to convert to coil over. I also have the top hats and bearings/ spring plates ect to basically build a full set of front Struts.
For this lot I would consider around $200 for the struts without springs, and $300 with the newish king springs, if you see my Avatar pic thats what they look like on my car.
NO HUBS OR BEARINGS.
