WTB A15 Engine Dipstick
Posted: Mon Aug 27, 2012 12:03 am
Hi guys,
Looking for an A15 Engine dipstick. Cheers.
Regards,
Braasy
Regards,
Braasy
Worth a try/comparison if that's cool with you?classicdat wrote:I've got an A14 (T) one, not sure if they are the same.
See you in Octoberclassicdat wrote:Not a problem Braasy, just pop around when you're free![]()
Where is your dipstick hole & what is your sump like?
You and me both, but it would appear notfunkydato wrote:thought a12 would be the same??
Early a12 like in a B110 car has the dizzy at the front and the dip stick goes into a hole drilled into the block, Mid dizzy motors have a tube that comes up from the block, between the oil pump and the fuel pump as per Braasy's image. Early a12 dipsticks are solid wire, with the H-L area crimped flat, a15 is flat steel riveted on to a wire handle. The lengths are also different.funkydato wrote:thought a12 would be the same??
Uh oh... Speaking from experience it would seem Vaughan hahaclassicdat wrote:Early a12 like in a B110 car has the dizzy at the front and the dip stick goes into a hole drilled into the block, Mid dizzy motors have a tube that comes up from the block, between the oil pump and the fuel pump as per Braasy's image. Early a12 dipsticks are solid wire, with the H-L area crimped flat, a15 is flat steel riveted on to a wire handle. The lengths are also different.funkydato wrote:thought a12 would be the same??
Early ones can get caught in the crank web if they are put in wrong, locking the engine solid on start up
