Help pls, temp gauge not working
joelbrown
aka: Joel
Post by joelbrown »
I recently flushed my radiator and since then my temp gauge is on the piss. It hardly moves at all now, it used to get to half way and stay there during normal running and a little higher when givin a thrash. Now it barely moves 2mm from off position.... Thorts pls? Cheers
1990 1200 ute
Re: Help pls, temp gauge not working
Do you have an air lock? If there is no water to transfer heat to the gauge sender then it won't register as hot. Just a thought. Also you may have dislodged something off the block and it could be stuck in the Thermostat, holding it open.
mint16
aka: Brendan
Post by mint16 »
What Vaughan said.
Might pay to remove and check thermostat AND temp sender, as sender may be surround by a buildup too.
joelbrown
aka: Joel
Post by joelbrown »
groovy, ta. i will whip them both out n hava look see. -pretty sure the thermostat is wkn tho as wen i re-filled radiator (after doin flush) i ran eng 4 a while with rad cap off n after a wee bit wen it got hot the water level in rad dropped big time (and i topped up accordingly) - i assume that wud be the thermostat crackn open and doin its job yo
1990 1200 ute
joelbrown
aka: Joel
Post by joelbrown »
Temp sender looked ok, no crud build up, no air lock. As far as thermostat, it wasnt jammed up n didnt look dodgy, but im certainly no expert- honestly its the 1st time ive ever pulled 1 out. -- im thinkn i mite aswell jst go shoppin 4 a new thermostat and temp sender n c wots the go
1990 1200 ute
DO you have a ohm meter, I could tell you the readings on my sender and you could compare, I'd imagine they are the same.
joelbrown
aka: Joel
Post by joelbrown »
Damn no i dont have a multimeter/ohmmeter
1990 1200 ute
510BRE
Area Reps
aka: shane
Post by 510BRE »
if you want to test a couple a things get a mate to sit in the drivers seat and watch the temp gauge while you unplug the wire from sender and touch the wire on earth breifly and if your mate see it move then gauge is good
joelbrown
aka: Joel
Post by joelbrown »
cool, ta, will try that
1990 1200 ute
joelbrown
aka: Joel
Post by joelbrown »
All fixd nw :D - Took shanes advice n checkd gauge, all gd, installed nu thermostat (wasnt the prob but gd piece of mind) managed to get a 2nd hand temp sender and nw its all wkn better than eva. It used to only jst gt onto gauge, nw it gts to jst b4 half way at runnin temp.
1990 1200 ute
