Page 1 of 2
Help pls, temp gauge not working
Posted: Mon Sep 24, 2012 10:57 pm
by joelbrown
I recently flushed my radiator and since then my temp gauge is on the piss. It hardly moves at all now, it used to get to half way and stay there during normal running and a little higher when givin a thrash. Now it barely moves 2mm from off position.... Thorts pls? Cheers
Re: Help pls, temp gauge not working
Posted: Mon Sep 24, 2012 11:03 pm
Do you have an air lock? If there is no water to transfer heat to the gauge sender then it won't register as hot. Just a thought. Also you may have dislodged something off the block and it could be stuck in the Thermostat, holding it open.
Posted: Mon Sep 24, 2012 11:30 pm
by mint16
What Vaughan said.
Might pay to remove and check thermostat AND temp sender, as sender may be surround by a buildup too.
Posted: Tue Sep 25, 2012 8:10 pm
by joelbrown
groovy, ta. i will whip them both out n hava look see. -pretty sure the thermostat is wkn tho as wen i re-filled radiator (after doin flush) i ran eng 4 a while with rad cap off n after a wee bit wen it got hot the water level in rad dropped big time (and i topped up accordingly) - i assume that wud be the thermostat crackn open and doin its job yo
Posted: Tue Sep 25, 2012 9:57 pm
by joelbrown
Temp sender looked ok, no crud build up, no air lock. As far as thermostat, it wasnt jammed up n didnt look dodgy, but im certainly no expert- honestly its the 1st time ive ever pulled 1 out. -- im thinkn i mite aswell jst go shoppin 4 a new thermostat and temp sender n c wots the go
Posted: Tue Sep 25, 2012 9:59 pm
DO you have a ohm meter, I could tell you the readings on my sender and you could compare, I'd imagine they are the same.
Posted: Tue Sep 25, 2012 10:11 pm
by joelbrown
Damn no i dont have a multimeter/ohmmeter
Posted: Tue Sep 25, 2012 10:23 pm
by 510BRE
if you want to test a couple a things get a mate to sit in the drivers seat and watch the temp gauge while you unplug the wire from sender and touch the wire on earth breifly and if your mate see it move then gauge is good
Posted: Tue Sep 25, 2012 10:36 pm
by joelbrown
cool, ta, will try that
Posted: Wed Oct 03, 2012 5:35 pm
by joelbrown
All fixd nw
- Took shanes advice n checkd gauge, all gd, installed nu thermostat (wasnt the prob but gd piece of mind) managed to get a 2nd hand temp sender and nw its all wkn better than eva. It used to only jst gt onto gauge, nw it gts to jst b4 half way at runnin temp.
