Thermostat position?
- joelbrown
- aka: Joel
Sup, im puttn a new thermostat in jst nw, spring side into eng rite? but wots the story with the small, loose rivet like thing? top or bot? - cheers
1990 1200 ute
Re: Thermostat position?
Yes you are right Joel, and the loose rivet thing allows air to bleed from the head to the to hose, so put it to the top
Good on you mate, good to hear about guys doing it themselves and having a go.
- joelbrown
- aka: Joel
Ledgendary, thanks man, was about to bite the bullet and put it bak in as no1 had replied , thort id cm inside n chk the post 1 last time tho- n saw ur reply! gd pice of mind to no its dun rite, cheers again
1990 1200 ute
