Waterpump help!! Pleease :(
all else goes here...
niccy
Datsun Driver
Post by niccy »
Can someone help me with my waterpump lol?
The water pump was running vicas and now I've changed to
Non vicas as its running an electric fan now. I tried an a series and l series pulley but both weren't correct.. I'll post a photo soon if anyone has any spare and poss z series???
2 doors
Re: Waterpump help!! Pleease :(
Post by 2 doors »
just to clarify, you have taken the viscous fan off, and now need a pulley with no fan on it?
I dont have one but might help others to understand what you need.
torqued
aka: Adam
Post by torqued »
Wouldve thought the Vfan bolted onto the pulley,
So removing the fan just meant bolting the pulley in place without fan,
Pic for reference
niccy
Datsun Driver
Post by niccy »
That would've be nice but it's all Welded together from factory..
Niccy can you remove the fan from the viscous and just run it like that, some bolt on the back of the coupling.
broke
aka: John
Post by broke »
Couldn't you just run a L series water pump and pulley with no viscous or solid fan? All my L's have it bolted on like Adam said, and AFAIK the Z and L are pretty much the same(ish) block.
niccy
Datsun Driver
Post by niccy »
Dan1200sss grinded the viscous pulley off because there was no room with the radiator.. If that makes sense? Then ground it completely off when we did the waterpump as it was welded on..
Ill upload a photo tonight. I have tried an L series and it doesnt match correctly.. Anyone have a zseries/z20 Pulley I can try?
braasmonkey
Site Admin
aka: Braasy
Post by braasmonkey »
niccy wrote:That would've be nice but it's all Welded together from factory..
To avoid confusion, could it be someone post factory has welded the water pump? Sounds odd otherwise...
- Braasy
dan1200sss
Datsun Driver
Post by dan1200sss »
I assure you, it is factory welded. there is no bolts holding the waterpump to the pulley etc. The waterpump thats to replace it is a z20 pump and bolts up etc to the motor and has 4 bolt holes/stud holes to fix a pulley to, so that's what we're after a pully to fit/make
Fit.
Do you have the offset, PCD etc any centre hole, diameter, of hole and pully.
Thanks
