Hey all, my 1200 has standard front drums, 45mm strut body.
Bit green with mixing and matching datsun bits, does the later 50mm shock with disc brakes bolt in?
Basically need the strut body to be 50mm to be a better fit with the adjustable sleeve/spring combo I bought and hubs that will support a disc.
I have wilwood calipers for the front but need to get the disc back as far as possible to A: clear 13in superlites and B: fit the largest diameter disc I can.
Otherwise I would just slip a disc over my existing hub.
Thanks
