Hi guys got a query regarding the r31 coilover setups
I need to shorten the R31 strut by about 1-2" has anybody done
This before and have the part number for the insert?
I read some where KYb 365092 but would rather
Know from somebody who has been down this path before
R31 coilovers into 1600
- illusive
- aka: Chris
Re: R31 coilovers into 1600
anybody help at all?
Assuming DIY coil over setup?
Is the perch wound down as far as possible?
Keeper springs no option ?
Why can you shorten your current struts?
- illusive
- aka: Chris
Yeap DIY, can do keeper springs but i still dont think its going to go low enough and retain full suspension travel i found an american forum that had the part numbers for shorter ones so i've gone and ordered sometorqued wrote:Assuming DIY coil over setup?
Well share the knowledge then
- illusive
- aka: Chris
will do, once its a proven setup ill take a few pictures and post them up hopefully will have them done by mid next week
My old setup was r31 struts with the 1600 perch and an rx2/rx3 spring as there slighty harder.
Have gone to a platform adjustable coilover now welded into the stub housing.
