How do i find out what year my datsun 1600 is?
It is registered as a 1974 which a quick google says there isnt such a thing..
Is there a way of looking up the vin code or anything to tell me what actual year it is?
Also means cheap rego would come alot sooner.
1974 datsun 1600
Re: 1974 datsun 1600
It'll be registered as the year it was first registered. Not when it was built. It wasn't uncommon for cars to sit around for a while before they were sold.
- aka: Dan
as Bart said.
But if you still want to know, then post up a bunch of pics, including dash, grille, indicators, and boot/rear tail light panel
- illusive
- aka: Chris
Dash is just the same as my 70 1600,
Grill etc is all the same to what are the differences between 70 71 72 73?
its this one here http://www.retrotech.co.nz/Cars/Datsun-1600-Z18ET.php" onclick="window.open(this.href);return false;
says 1973 on there aswell its rego'd 1974
A 1970 has white needles in the dash and normally DATSUN is on the tail light panel above the number plate and a black dash to not gray everything else the same as 71 72 73
- illusive
- aka: Chris
Well it didnt have DATSUN on the back, but i will go check the dash tomorrow cheers dudechris_g1 wrote:A 1970 has white needles in the dash and normally DATSUN is on the tail light panel above the number plate and a black dash to not gray everything else the same as 71 72 73
- Area Reps
- aka: shane
are you able to chuck up a photo off the rego sticker you can blank out rego number ..also look on the inside off engine bay down beside radiater where the horns face is there round holes or some other shape .........
- illusive
- aka: Chris
Sure if i can find it, will have a look at body tomorrow as its in bits mid resto510BRE wrote:are you able to chuck up a photo off the rego sticker you can blank out rego number ..also look on the inside off engine bay down beside radiater where the horns face is there round holes or some other shape .........
- pl510
- aka: Shannon
Looks like a '72 to me
