the easiest way?
- aka: Ryan
the easiest way?
Hey guys whats the easiest way to get to head unit in the datsun sunny wagon? Anyone got a step by step guide how to do it?
- mint16
- aka: Brendan
Re: the easiest way?
Locate a wire that has permanent 12v.
Locate a wire that has accessory switched 12v.
Make an earth wire to connect to dash frame.
Connect these to the corresponding headunit harness wires and headunit will run.
- aka: Ryan
Cheers brendon got that bit sorted its the plastic surround I want to get off so I can mount head unit.
pull off the heater knobs, and carefully lever off the heater control bezel with a flat blade screwdriver. There is a pair of screw behind it. Those are the hard to find screws. The rest of the screws to remove the dash bezel should be easy to find with a bit of perseverence.
You may also need to remove the steering wheel, and the steering column shroud.
- aka: Ryan
Cheers will have a go tomorrow and asked a guy about how to get choke so should have everything covered thanks heapsBartman wrote:pull off the heater knobs, and carefully lever off the heater control bezel with a flat blade screwdriver. There is a pair of screw behind it. Those are the hard to find screws. The rest of the screws to remove the dash bezel should be easy to find with a bit of perseverence.
Push and twist the knob. Then undo the nut behind it.
