1200 ute disc brake pads and wheel brgs
- joelbrown
- aka: Joel
Howdys, im after new frnt wheel brgs and disc pads for my 1200 ute, the useless heads at repco cant find a listing for the part numbers tho, any ideas yall? Cheers
1990 1200 ute
Re: 1200 ute disc brake pads and wheel brgs part #?
Genuine Nissan Part #
Nut Lock Front Wheel Bearing - 08114-06510
Washer Lock Front Wheel bearing - 40264-18000
But just go to BnT next time. They will sort you out
i got some pads from bnt a while ago, pretty cheap. they should do bearings as well, but failing that i use saeco for all my bearings. it usually pays to take your ones in as samples so you can get the correct ones 1st go
