I am desperately in need of 12mm R200 Ring Gear Bolts.
My only set got machined down to 10mm to be used in a different diff and now I need 12mm Bolts again
I can swap for
10mm Ring Gear Bolts + Spacer tubes so they can be used in 12mm LSD's
Machined down 12mm bolts that have been re cut to 10mm thread's to be used in 12mm LSD's
Let me know what you have.
I need them pretty fast too, new Pinion Bearings have been ordered , needs built ASAP
