have decided to change the auto to a 5 speed send I needed to change the engine anyway, easier to just pull motor and box out together and vis versa.
So I am after a 5 speed cross member if any one has one.
thanks
B310 parts wanted
- woodies72coupe
B310 5spd gearbox cross member wanted
You just can't help but pull it apart!!
- kartboy
- aka: Hayden
Re: B310 parts wanted
So now that i have done this conversion i now need to replace some parts on the coupe that got borrowed.
I need either a 5 speed gearbox crossmember or at worst an auto one that i could modify to fit and
Also need the piece on the firewall where the clutch cable goes through.
Thanks
Thanks
Hayden
I have a variety of possibly 110/210/310 gearbox X-members, but I can not identify what they are, or whether they would suit.
Can you dimension up a sketch of the fixing hole locations on your trans tunnel?
cheers
Kitch
cheers
Kitch
Brdflu
- aka: Scott
Hey mate
I might have the bit for the clutch cable of the firewall.
Will have a hunt this weekend and let you know.
1956 Morris Minor - one day A12
1982 Sunny wagon - A15 dogleg 5 speed
1984 Toyota Corona Mark 2 - GX61
