Hi Guys
I have been thinking for some time we could get a list going for people in Datsun City who are willing to loan out Datsun Specific tools that are out of the ordinary or custom made.
I will begin and as we get a list going I will update the first post, if we get enough intrest we could make this a sticky.
Copy and paste this template & I will go first
User name
Tool name
Description
Cost
Contact method
Location
85_Z31 (James T)
*Driveshaft Flange power bar ( suit round and square flange )
long piece of steel flat bar (to hold 2 bolts in the diff pinion flange so you can undo the bolt with a power bar)
$10 bond, returned to borrower when tool gets returned.
*R200 Longnose Empty Diff case
Good for test fits into your R160 IRS Datsun - with rear cover.
No cost
Contact Via PM
Rangiora North Canterbury
Crustywhip (Kane)
'A' frame
Adjustable width to suit most cars. Requires two tow hooks on the front of the towed car to bolt too. I made lower tow hooks to fit under chin spoiler. No Mrs letting that rope go slack ever again.
$5 fish and chips
Text 0273380164 or call 021311572
Christchurch City or there abouts
Brocky41 aka Brock
Engine Crane w load leveler
lifts stuff up to 1500kg (including car body's onto trailers to go to scrap.
2500kg Wayco low lift jack
Gets under all my lowness, gets higher than your shitty super heap stuff.
Pair of car yard ramps -
Get your ride a metre off the deck for gearbox swaps and fuelline making, cleaning etc
Water blaster
$15 for as long as you need over a weekend.
Ball joint splitter Fork type
All stuff on a you break it, you fix / buy it - hope this helps others out.
Brock - 0273380347
Belfast - Christchurch
Kitch
Hydraulic bottle jack small shop press
(just a wee supercheap one for pressing out bearings, wheel studs etc)
Repco Battery Charger
(8 amp I think)
Engine stand
Axle stands
Torque wrench
Trolley jack
Free Short Term loan
Kitch - Timaru
0272910351
Gingofthesouth
- Powerbuilt Engine Crane
- Powerbuilt Engine Stand
- Trolley Jack
- Axel Stands
- Torque Wrench
- Spring compressors (for removing springs from struts when you are installing lowering springs etc)
Short term loan when I am not in need of it. You break it, you fix it or replace it.
Cost = A Revive Espresso Coffee
Petone, Wellington.
NzDatsun.com Tool Loan Thread - pg 1 tool master list
- Datsun Addict
- aka: Kane
Re: NzDatsun.com Tool Loan Thread
Good idea;
Crustywhip (Kane)
'A' frame
$5 fish and chips
Crustywhip (Kane)
'A' frame
$5 fish and chips
Brocky41 aka Brock
Not custom etc but will help someone out
Engine Crane w load leveller - lifts stuff up to 1500kg (including car body's onto trailers to go to scrap.
2500kg Wayco low lift jack - gets under all my lowness, gets higher than your shitty super heap stuff.
Pair of car yard ramps - get your ride a metre off the deck for gearbox swaps and fuelline making, cleaning etc
Water blaster - $15 for as long as you need over a weekend.
Fork type ball joint splitter - bit rangi but good for taking old shiz off.
Brock - 0273380347
Will put pics up soon.
Brock - 0273380347
Not that they are specialist tools, but tools all the same that I did not always have, and were always borrowing from my mechanic neighbour etc, until recent years, I have started to buy a few things I have needed!
If you are in Timaru and have limited access to tools, and need any of the following, for free short term loans,
and I am not using them at the time, then yell out:
- Hydraulic bottle jack small shop press (just a wee supercheap one for pressing out bearings, wheel studs etc)
- Repco Battery Charger (8 amp I think)
- Engine stand, which has had a few A series motors on it, and also some EJ20T's
- Couple of pairs of axle stands
- Torque wrench
- Good solid "low-ish" trolley jack (decent one)
Probably other stuff I have forgotten too....
Kitch
0272910351
- Torque wrench
Kitch
0272910351
gingofthesouth
- Trolley Jack
- Axel Stands
- Torque Wrench
Petone, Wellington
- Trolley Jack
- Axel Stands
- Torque Wrench
Petone, Wellington
Re: NzDatsun.com Tool Loan Thread - pg 1 tool master list
broke
510 dollies - these bolt on where your front crossmember and rear moustache bar would go. They have braked casters fitted, so you can roll your 510 body around while you prep/paint it. Made them to move my car around, hopefully I won't need them ever again
You can buy them from me for $100 which is less than the cost of the materials in them, or borrow them for a box of beers
Contact method: PM or text 02102310952
