Pip needs some front hubs from a 4-stud Z31.
Anyone know where to find some?
Z31 front hubs - 4 stud
- aka: Dan
Re: Z31 front hubs - 4 stud
i think i still have my S12 ones somewhere.
from what i seen, they are the same as Z31 4 stud.
discs are rooted though...
they are the disc bolted to the back of the hub type.
- aka: Dan
If you can find them, can you measure the height of them for us?
If they are about 80mm then they'll be perfect
sorry for the slow reply, i could only find one.
of course i found the other in the first place i looked to start with
as i said discs are shot, and it looks like the studs arent original either.
z31/s12 have the shortest studs ever, and the last owner put something else in there.
one studs missing as i took it out to source new ones. no biggy, im picking most nissan studs are the same.
hope these are the dimensions you were after?
rear seal is 46 X 59.1 X 12, which is the stub size for the larger cars s12/r30/z31 etc.
- aka: Dan
Awesome this heaps for that!
The 75mm was what i was after.
I was hoping it'd be closer to 80mm, but that should be close enough.
Are yours for sale?
I'll have to check with James first since he this he's found some z31 hubs too
Are yours for sale?
yeah surplus to my needs.
im using r31 hubs in both my cars now.
i you want them they are yours, but probably better to remove the discs first if you want send them down, as they are pretty hefty.
let me know if you need them.
cheers.
cheers.
your all good to go dan.
few people said they were looking for me but no result as yet.
go nuts on vegies hubs
- aka: Dan
Sweet, you heard the man.
How much you after inc postage?
Don't need the disc
Don't need the disc
will split the discs off, you pay postage and they are yours!
but wait theres more! (i might even clean them lol)
pm me some details if you want them...
Can Dan please have all the lock washers and wheel bearings and dust caps / nuts and bits and pieces ?
