Hi guys i have 1974 Datsun 120y coupe that iv panled myself on the weekends for the last couple of years and have just had it painted dark blue, you may have seen it cruising round the streets of christchurch
i am in desperate need of a boot lock and outside door rubbers
other parts im looking for to are a radio aerial, cigarette lighter, and also a centre console in good condition
if you can help with any of these things or point me in the right direction please let me know id be very grateful
i will definitly return the favour
heres my contact number 0277649084
Desperate need of boot lock and outside door rubbers!!
- Josephbary
- aka: Joseph
Re: Desperate need of boot lock and outside door rubbers!!
Hey mate I just bought some outside rubbers for my 120y coupe off eBay they were all good and much cheaper than rare Spares. Just had to trim them a little to fit .
- woodies72coupe
Got a lot of bits and pieces coming from a sedan shortly. Prop 2-3 weeks after Easter if you are still keen? So could help
- Josephbary
- aka: Joseph
Hey jrods210 i had a look on ebay but i can only find the rubbers that go around the window. I need the rubbers that go on the outside edge of the window horizontally and they scrape the water off the window. Would you be able to link me to the ebay auction please?
And woodies72coupe that would be awesome! could you txt me when your in so i can come have a look? my numbers 0277659084
- woodies72coupe
Where abouts are you in nz? Car is down south
yea those are farken annoying to find i thought you meant outer door rubbers. i got some of those off ebay too and got new clips from rare spares ill take a photo. im not that happy with how they look compared to the original ones but they are at least water tight now and my window is not nearly as ratley as t used to be. rare spares do the rubber but there $90 each side
these are the seals i boughthttp://www.ebay.com/itm/310410788448?ss ... 1423.l2649
and used these clips i did have to trim some length of theme though http://www.rarespares.net.au/rsnz/Produ ... ct=DBC1003
- Josephbary
- aka: Joseph
woodies72coupe Im in christchurch but can always go for a drive if closeish
and jrods210 thanks for your help i think i may look a bit longer but at least i know somewhere to fall back on anyway. cheers
- woodies72coupe
Send me a list of stuff you need. I will prob strip the car and bring it back for you. She's a long way south. Pretty much the whole car less running gear and some front panels.
heres those pics sorry about the light
- Josephbary
- aka: Joseph
Cheers for the picture jrods210. They dont look too bad, i guess if i have no luck il end up just getting those ones off ebay
Also what colour is your one?
