3x Datsun 1200 steering boxes all in good condition. One has been stripped cleaned and repacked with grease, other two as they came from cars, dirty but good to use $50 each
3 x Datsun 1200 drag links all in good condition $50 each
S13 rear calipers and rotors - $50 for the lot
Secondary Subaru Turbo, think its the bigger of the two, Was going to use to turbo an a12, its pretty small $30
1200 Sedan dash - good condition Foam hasnt warped or split but there is a chip out of the plastic on the top surface $50
1200 Sedan dash cluster - good condition $20
Box of interior bits, all aluminium sill trims, various plastic trim etc, origanal tool kit. $50
Brand new interior light plastic $20
4 x Brand new 45mmx90mm long Jenvey airhorns with matching watercut flanges $200. Pretty sure they is the same bolt pattern as Side drafts. will confirm.
Heavy duty 1/2hp bench grinder with three spare grinding stones $100
1200 sedan door cards one door card is cracked. vinyl is pretty good condition no rips a bit faded, might be able to swap to better cards? $10
1200 sedan roof vinyl, no rips tears needs a real good clean has all roof spars. $20
Brand new 1200/120y/sunny bottom arm bushes Nolathane $30
Will ship everything except grinder
Stupid Photobucket took half an hour to upload so Im guuna dump all the pictures here, im sure you can work it all out
