Nicks garage clearout, Something for everyone!!
Posted: Mon May 20, 2013 10:20 pm
Pictures to come tomorrow, camera is charging. All Prices negotiable
3x Datsun 1200 steering boxes all in good condition. One has been stripped cleaned and repacked with grease, other two as they came from cars, dirty but good to use $50 each
3 x Datsun 1200 drag links all in good condition $50 each
S13 rear calipers and rotors - $50 for the lot
Secondary Subaru Turbo, think its the bigger of the two, Was going to use to turbo an a12, its pretty small $30
1200 Sedan dash - good condition Foam hasnt warped or split but there is a chip out of the plastic on the top surface $50
1200 Sedan dash cluster - good condition $20
Box of interior bits, all aluminium sill trims, various plastic trim etc, origanal tool kit. $50
Brand new interior light plastic $20
4 x Brand new 45mmx90mm long Jenvey airhorns with matching watercut flanges $200. Pretty sure they is the same bolt pattern as Side drafts. will confirm.
Heavy duty 1/2hp bench grinder with three spare grinding stones $100
1200 sedan door cards one door card is cracked. vinyl is pretty good condition no rips a bit faded, might be able to swap to better cards? $10
1200 sedan roof vinyl, no rips tears needs a real good clean has all roof spars. $20
Brand new 1200/120y/sunny bottom arm bushes Nolathane $30
Will ship everything except grinder
Stupid Photobucket took half an hour to upload so Im guuna dump all the pictures here, im sure you can work it all out
