I reckon it will be a really neat conversion if I find a way to bolt them together.
I was thinking of getting a few of these bungs and welding to on the side of the rad, then 2 on the side of the IC and using a alloy bracket between them with 2 holes in each and a couple of bolts
Thoughts? Below is the rad and IC
So maybe either side mounts, or top and bottom as the IC already has some bungs
Any input appreciated.
Thanks
