I need to buy or borrow some 4 & 5 stud 114.3 wheels, really need to be 16 or 17 inch with an offset around +35 or lower. I need to get a warrant on the DR so I'm going to swap the front brakes back to the 4 stud originals but I don't want to swap the rear stub axles back out.
Preferably full face chromes but will consider anything.
4 & 5 multi stud 114.3 wheels wanted
Re: 4 & 5 stud 114.3 wheels wanted
I have a few different 4 stud 17's Dan.
Flick me a txt tommorrow arvo if you'd like to take a look.
I have no idea whatsoever what offset they are. Have wofable tyres though.
Sorry bro, should have worded that a bit better, I need a set of wheels that have both 4x114.3 & 5x114.3 stud patterns, the front of the car is going to be 4x114.3 and the rear is 5x114.3.
I've had a bit of a look on Trademe, there are slim pickings for anything half decent, there's a set of 17 inch SSR wheels that might do but they're in Auckland.
spiderwebfx
- aka: Chris
Are new wheels an option or only interested in used ones?
They're probably only going to be for one time use but I'll consider anything. The SSR wheels I was looking at are $500 with tyres so wouldn't want to go much more than that.
spiderwebfx
- aka: Chris
That's not a bad price if they are 4 and 5 stud. I don't think I have anything that will suit otherwise. I have some 15" Ford wheels that are 5x114.3 and then some random 15" Nissan wheels that are 4x114.3
can you find a couple 4 stud z31 wheels
I have many spare 5 stud ones you can borrow anytime
Re: 4 & 5 multi stud 114.3 wheels wanted
I think I still have some Z31 15s in 4 stud if you want them. I'd need to check
Could be a go cheap enough
http://www.trademe.co.nz/motors/car-par ... 146144.htm" onclick="window.open(this.href);return false;
Thanks man, I'll keep on eye on them but I think I've got this sorted thanks to James and Vaughan.
