FS : R200 Longnose , 3.545 OPEN Good Condition CHCH
Sell stuff
85_Z31
Post by 85_Z31 »
Hi Guys
I have advertised my R200 3.545 OPEN R200 Long nose on Trademe with no luck.
iff in good used condition 3.54 ratio, came in a group of long nose diffs that a friend scrounged up. Its fairly quiet in the car, no bearing noise and not leaking from any of the seals. I have looked at the ring gear and no suspicious marks or damage. It makes the slightest hint of gear noise but all in all its in good order for a 28 year old diff.
Perfect for fitting a 2way LSD into
Suit an R200 swap in your 240Z 260Z or bolt right into a 280Z or early 300zx
Also ideal for RB26/30 engine conversion.
In my Z31 cruising in 100 kmh in 5th gear is 2500rpm ( gps not speedo )
I think its worth $400 based on other Longnose sales on Trademe but I might be able to work something out for a club member :)
Pm me your offer if interested.
Also if you have an LSD i can fit this up for you.
Cheers,
James
85_Z31
Re: FS : R200 Longnose , 3.545 OPEN Good Condition CHCH
Post by 85_Z31 »
Tentatively sold :D
