Hi, just progressing my brake upgrade a bit and need to source a 7/8" (minimum) master for the rx7 4 pots. I was going to order the 7/8" master cylinder from maddat (http://www.maddat.com.au/brake-parts.php" onclick="window.open(this.href);return false; Product No - MC7/8) which I presume is a 280z replacement item.
It would be good if I could get something a bit more compact as this would sit very close to the super charger and I would like a reasonable amount of clearance to allow for engine movement.
Is there a 7/8" or 15/16" master cylinder that anyone knows of with the same bolt pattern as needed to attach to a b210/180b booster?
Shorter 7/8" master cylinder for b210/180b booster
jeremiahnz
1965 Bluebird 410
1976 Yamaha RD50
1976 Yamaha RD50
jeremiahnz
Re: Shorter 7/8" master cylinder for b210/180b booster
Still looking for master cylinder options as the datsun masters (i.e. 180b) have the bleed nipples in a position that could foul on the supercharger.
I have found some info that suggests that some Mazda master cylinders (i.e. rx7 s3, b series utes) are 7/8th bore (or greater), and share the same vertical bolt pattern with 60mm spacing as the datsuns have and that the 180b booster I have shares.
Has anyone ever tried one the Mazda brake master cylinders? Keen to hear if they do work before I spend $$.
1965 Bluebird 410
1976 Yamaha RD50
1976 Yamaha RD50
can you take a couple of pics of what you have and with it fitted to the car - i can check at work, BNT, as all the guys in our branch love to hunt that kind of stuff out.
Brock
Brock
jeremiahnz
Cheers Brock,
Here are a couple of pics.
The first one shows how close the bleeder nipples are to the supercharger, and whilst I understand I can probably get shorter bleeders, I want quite a bit of clearance as I don't want to take risks with the brakes. This pic just shows the bolt pattern the master cylinder. The current master cylinder is 3/4 bore, so I need to change it anyway, and I understand the 7/8 bore from the datsuns that would fit this (i.e. 180b or 280z I think) are pretty much the same master but with a 7/8" bore so it still has the same issue.
I found some stuff that suggested some Mazda master cylinders from around the early 80's (possible S3 RX7, or B series ute) have a 7/8" bore, have the bleed nipples on the other side, and have a 60mm vertical spaced bolt pattern and will therefore bolt up to the Datsun booster. Also they are dual circuit which I want (original 411 master isn't).
I'd also be happy with a 15/16" bore, as it is running RX7 4 pots up from and disc brakes in the rear. I have a Wilwood adjustable brake block (replaces the standard dist block plus has the front/rear bias adjust).
Thanks again.
Jeremy
Thanks again.
Jeremy
1965 Bluebird 410
1976 Yamaha RD50
1976 Yamaha RD50
Godzilladat
The 280z stuff from the USA should have the bleed nipples on the other side than your pic to suit a LHD. For more clearance you can get to the wreckers and steal the fluid caps and remote reservoir off a nissan urvan.
Remote reservoir
Remote reservoir
A 15/16 M/c from a 280ZX would be perfect as they have bleed nipples on the other side. 180B's are 3/4 not 7/8. 620 utes and R30 skylines are 7/8 I think but nipples might still be close to your supercharger. I do have a 280ZX m/c but pretty sure Bart has dibbs on it. However if you want to test fit one for the mean time I would be willing to send it up for test purposes as I doubt Bart will be using it anytime soon!
jeremiahnz
Thanks for that info. Do the 280zx have a vertical bolt pattern? I was under the impression they had a horizontal bolt pattern?
1965 Bluebird 410
1976 Yamaha RD50
1976 Yamaha RD50
The earlier ones do. I have fitted it up to my 180b booster before but the nipples fouled on my strut tower. Now have a 7/8 from a 720 with the nipples on the right side (well for me anyway) also running rx7 4 pots
jeremiahnz
Awesome. Where did you order your 280zx master from? How do you find your brake setup?
1965 Bluebird 410
1976 Yamaha RD50
1976 Yamaha RD50
My 280 m/c is second hand would've got it rebuilt if I was going to use it. Haven't tested my brakes yet not quite at that point!
