I paid $150 for it, + blasting + painting + $70 to inspect & balance it
Has balancing paperwork for cert if reqd (from Circletrack in CHCH)
Did not use as was 30mm too long for my coupe! I thought it was
an H165 roadstar short wheel base one and would be direct bolt in
replacement. I think it may be a 210 or possibly even a 310 unit.
Measures approx. 1330mm overall, tip of spline to rear flange
can get more accurate measurements when I get a chance
So A series manual gearbox one end and H165 diff flange the
other (or H150)
instead have modified a spare H150 drive shaft for my coupe
as did not want cut this up after all the work I have done on it!
