Hi.
Can anyone shed some light on to what offset
Would fit a 14x6 to a standard 1200 sedan?
Guards will be rolled but not pumped
Wheel offset for 1200 sedan
- aka: Tbag
Re: Wheel offset for 1200 sedan
I have 13x6 +10 on front which is same as your front end, coupes can have a wider rear rim I think, I have13x7.5 -6 on rear that are basically flush with standard guard. 6s will fit fine in sedan unless its some stupid massive positive fwd offset
1972 1200 coupe KB110
sedans = different aye lukeluke wrote:I have 13x6 +10 on front which is same as your front end, coupes can have a wider rear rim I think, I have13x7.5 -6 on rear that are basically flush with standard guard. 6s will fit fine in sedan unless its some stupid massive positive fwd offset
my orange sedan was running the os jellybean 13x6 with 185/60r13 and they rubbed as the rear door shut is the biggest pain in the arse.
Wheel offset and tyre size will need to be in your favour - low pro tyres and a 0 offset on a 6 should be sweet.
- joelbrown
- aka: Joel
I have seen a sedan with standard rear guards and zero offset 13x7's and slightly tucked 175/50/13 tires with no rub, damn close tho.
Not sure bout 14's
Not sure bout 14's
1990 1200 ute
my 13x8 0 offset wheels fitted onto the rear of andys 1200 alright
15p mate has always worked for me
- aka: Tbag
Thanks guys I guess I'll look at playing with
Tyre sizes before spacers
