Front brakes on 1200
- Evil13
- aka: kane
Starting to sort front end on the 1200 sedan did these all have drum brakes on the front including deluxe kind of want car semi original. Iv heard only coupes came disc brake factory is that right?
1200 sedan
1961 ford galaxie
1961 ford galaxie
Re: Front brakes on 1200
Nah some sedans came front disk, mine isn't delux and it came front disk...someone on here will surely know which models/years/nz made or something came with them front disk though
- Evil13
- aka: kane
Iv got a set of drum brakes off my ute so I'm debating weather I rebuild and fit them to sedan or buy a disc brake set up. iv already got disc brake master cylinder
1200 sedan
1961 ford galaxie
1961 ford galaxie
drum brakes were only on the early 1200 sedans (ie 1970-1972 or there abouts) the 1973-1974 ones had discs AFAIK
110 disc brakes are shit, the drums are even shittier....
S13 255mm brake upgrade is not expensive at all, $50 for adaptor plates, maybe $50-100 for discs & callipers & pads. and a wee bit for some minor machining & longer studs & bolts etc. I am running mine with original sized master cylinder. really quite an easy upgrade, and if you are looking at maybe $200-300 all up it is a cost effective upgrade.
Dont scrimp on tyres & brakes! thats what my old school boy racer uncle always told me when it comes to cars
- Evil13
- aka: kane
Iv got some old s13 brakes laying around but don't think they will work with my wheels. Ill need some disc brake struts to start with tho.
Yea iv had brakes fail before on the track with my silvia but I'm only going to be using a a12
1200 sedan
1961 ford galaxie
1961 ford galaxie
I only run an A12, and Std disc brakes, don't ask Bart his opinion of them, but I think Kitch described them well
They are fine around town, but out on the open road they do not inspire.
When you're pegged off the clock, the standard brakes can haul you down once. The second time they might stop you. The third time, they'll smell so hot it'll make your eyes water.
1200/120Y disc brake struts take S13 brakes with ease. Problem solved.
- Evil13
- aka: kane
I'm getting a set of sunny struts this weekend I don't think my wheels will clear s13 brakes they rub on the r30 struts i have to run spacersBartman wrote:When you're pegged off the clock, the standard brakes can haul you down once. The second time they might stop you. The third time, they'll smell so hot it'll make your eyes water.
1200 sedan
1961 ford galaxie
1961 ford galaxie
Just cos R30's don't fit, doesn't mean S13 wont.
