habitz 510 toy
Posted: Tue Sep 03, 2013 12:34 pm
thought i'd start a build thread for my latest frivolous expense.....or so i'm told!
Pretty stoked to get a 510 after wanting one for a while.
should be nestled in it's new home in auckland on wednesday.
It's an original '72 black plate car. It's been through a few different hands obviously and at some stage had a CA18DET swap done. I assume matching g/box etc.
My plan is to get it on the road so i can have a play thing while the 240Z is coming along. Then maybe take it off the road for a major overhaul.
Body is pretty good with only one rear dogleg needing attention and a few bubbles here and there but overall paint is good. Painted in a 2 pak in good shape
Interior has had some fiddling too. I'd like to return it to something closer to stock with maybe some recaros. I think the factory did a good job on these early cars so why play with it to much.
Door panels have been covered in vinyl. A new set is in the works already. Replace the rough wheel with a sportline. etc etc. nothing fancy
I'll try and do updates regularly.
Cheers to all. and if you do know any info on the history of this car post it up.
