ok so i have a little problem with the rear wheels facing inwards on my 810 I changed the rear arms to r30 as to get the disc brake rear end but now i have toe much toe. looking round i found that people slot there mounts for the arms, but i think i may have found an easier answer
i found my old r 30 rear subframe did a couple of checks and the slots the arms bolt into are fractionally longer about 10mm so all going well it should fix the problem but now the whole ass end has to come out again.........
i'll keep you's informed
180b rear toe woes
- MONTY
Re: 180b rear toe woes
ok stripped the 180b subframe out yesterday and compared it to the r 30 one i had lying around and there is a bit of a difference, the outside mounts are around 10mm longer and the inside ones are about 2-3mm and have some extra reinforcing, here's some pics to show yous
so hopefully this will fix this stupid toe issue i've got
