Garage Tidy Up - Parts for Sale
Sell stuff
detdat
aka: Cam
Post by detdat »
Having a bit of a tidy up of the garage so here's a list of things that need to go:
Chrome Air Filter for standard A12-A15 Carb, : Clamps onto top of carb, will need a new filter element: $25
Sway Bar,Powder coated Yellow, 20mm diameter. Not sure if its of a B210 or B310 - Can measure if needed $40
Dellorto DHLA 40 Parts - Enough to build one complete carb and have some spare parts. $150
Inlet Manifold for A12 - Suits 40mm Side Draughts $100
Datsun 1200 Castor Rods - Extra thread machined for more castor adjustment ( Suits standard struts and control arms) $35
White Gauge Cluster for Datsun 1200 -Includes Tacho $80
A series Heavy Duty Valve Springs - Suit a mild cam $50
Roadstar Ute Dash Cluster No speedo - Has damaged PCB tracks $20
Open to offers as well if nothing sells.
Cam
Tony_Whenua
Re: Garage Tidy Up - Parts for Sale
Post by Tony_Whenua »
Dibs on sway bar if b210!!
Can you measure please??
nzdatman
Post by nzdatman »
I'm keen on those dellorto parts, can you give some details about what's there, jet sizes choke sizes etc, and is there are fourth auxiliary Venturi? Could only see three in the pic
detdat
aka: Cam
Post by detdat »
Tony_Whenua wrote:Dibs on sway bar if b210!!
Measured:
Kitch
Post by Kitch »
could be keen on the valve springs.
will have a think about it, and if it will suit my application
Tony_Whenua
Measured:
B310 is 955mm right so this one should be sweet ... Any one able to confirm this??
I couldn't find any info on b210 measurements
Kitch
Post by Kitch »
I tried to fit a 310 sway bar to my coupe a while back - no good, as was too long by about 30mm (?).
needs to be 210 to fit easily
beaver
Post by beaver »
I can measure mine (120y) tonight if that helps? they are the same size (but thicker) than the 1200 ones yeh?
Tony_Whenua
beaver wrote:I can measure mine (120y) tonight if that helps? they are the same size (but thicker) than the 1200 ones yeh?
Thanks man that'd be great. I'll try measure my 1200 tonight too and see what that comes up as
nzdatman
Post by nzdatman »
Any news on the dellorto parts?
