1171dato
Posts: 33 Joined: Thu Aug 22, 2013 7:57 pm
Post
by 1171dato » Thu Nov 07, 2013 9:58 pm
hi im looking for above
this is the manifold im after
mostly found on pre 89 nissan terrano
85_Z31
Posts: 1494 Joined: Sun Jul 18, 2010 10:53 pm
Post
by 85_Z31 » Fri Nov 08, 2013 6:08 pm
Looks like the very Rare VG30i Carby manifold from vehicles delivered to the middle east.
The amercians modify an early pathfinder plenum to look like this for use with a Carby
http://i9.photobucket.com/albums/a96/st ... intake.jpg " onclick="window.open(this.href);return false;
you might be more likely to find the VG30 TBI manifold and have it modified.
I don't think there will be much VG30 Carby stuff in newzealand unless it has been scratch build.
1171dato
Post
by 1171dato » Fri Nov 08, 2013 8:48 pm
this is what I wanted to do with the manifold
I really want to use a carb I may even make a manifold myself yet
Posts: 3260 Joined: Wed Apr 21, 2010 9:59 pm
Post
by classicdat » Fri Nov 08, 2013 9:35 pm
Individual runners with sidies
85_Z31
Post
by 85_Z31 » Fri Nov 08, 2013 9:54 pm
CNC manifold flanges are available to allow you to weld up and fabricate any sort of manifold you want
1171dato
Post
by 1171dato » Fri Nov 08, 2013 9:58 pm
don't plan to spend to much on the egine as I still need plates and cert but 6 R1 carb would be the duck's nut's three carb each side
to look like this
carb's and tuning Cost's are holding me back on this idea
torqued
Posts: 2125 Joined: Sat Jul 19, 2008 11:49 am
aka: Adam
Post
by torqued » Fri Nov 08, 2013 10:10 pm
You would be better with EFI
1171dato
Post
by 1171dato » Fri Nov 08, 2013 10:15 pm
I don't want/like the look of the efi set up with all the wires and shit one carb easy to tune later on with big cam's etc
torqued
aka: Adam
Post
by torqued » Fri Nov 08, 2013 10:16 pm
That picture you posted is EFI
1171dato
Post
by 1171dato » Fri Nov 08, 2013 10:23 pm
torqued wrote: That picture you posted is EFI
lol if I found one with carb's I would have post that
