Datsun 1600 Parts needed
RatsunDatsun
Post by RatsunDatsun »
All, have been chasing a few 1600 bits for a while now. Any help with the below would be very much appreciated.
I am only interested in parts in good condition.
- Wheel chocks
- Jack winder (with plastic sleeve which rotates when winding)
- Tool bag and tools
- Choke cable/handle (my handle is fine, but where the rod end that mounts to handle and cable is broken)
- Standard air box
- Metal Fuel line between fuel pump and carb
- Front guard badges
- Sump guard
- Radio mount bracket for standard radio
- Spare wheel fastener
- Undamaged water bottle motor and rubber
- Front parcel tray
- Sun visors (see type attached)
- Rubber boot mat
- Steering wheel (see type attached)
- Real tail light deviders (ie steel piece inside tail light assembly between the park light/indicator and tail light)
- Boot badge (with all pins)
- Accelerator pedal
- Gear stick metal cover plate (mine was modified to fit 5 speed some time ago)
Thanks
