FS5W60A assembly B310 5 speed gearbox
Surfez
Post by Surfez »
Just incase, like me, you think you'll remember how to assemble your shift forks and synchro shafts without help, or you assume your workshop manual will cover the 5 speed box, you spend hours trying to figure it out and searching the net, invite a friend over and then find in the "Supplement" section of your workshop manual! not the gearbox chapter, it does cover the 5 speed for later models. This is not a dog leg box. Hope this may help someone if assembly becomes an issue as these things have many ways of fitting together when it comes to shift rods.
Surfez
Re: FS5W60A assembly B310 5 speed gearbox
Post by Surfez »
Finnished product, just had an inspection and lapped in the slip rings with some valve paste.Painted it up to look tidy from the engine bay and under side, the alloy was rough and I sure wasn't going to buff it.
