WTB: 2" Blocks and Ubolts to suit my b210 120y wagon - blen
damz721
aka: Damian
Post by damz721 »
As above, happy to pay shipping i am located in blenheim but can pickup if in nelson.
Cheers,
Damian
- 77 B210 S/W
beaver
Re: WTB: 2" Blocks and Ubolts to suit my b210 120y wagon - b
Post by beaver »
I had a bit of a piss around getting blocks for mine (coupe, although I suspect they are the same).
The locating pin on the springs is 12mm or so, however there is a steel spacer/clamping plate which sits on the spring, using said locating pin. The crunch is that the locating pin on top of the spacer is 36mm (I think) and so the diff needs a pin 36mm.
The ones I got listed for a b210/120y were for a 12mm pin so they fitted the leaves but not the diff. So I had to get some that had a 36mm pin and cut it down to fit into the diff. Got there in the end.
Moral of the story pull the rear end apart and take some measurements first.
beaver
Post by beaver »
Also be a man and get them reset as well :D 2" blocks wont be low enough
damz721
aka: Damian
Post by damz721 »
I'm going to get them reset first just need to find a place that does them in Marlborough/Nelson area
- 77 B210 S/W
