Here she is, 1972 Datsun 240z, ex race car. Very rusty. L28, extremely lumpy, high compression ratio with triple 45mm DCOE carbs, was built by Wayne Murdoch. Has live plates and original ownership papers. Half cage, adjustable suspension. Going to try get in contact with Wayne Murdoch at some stage to find out a bit about the engine.
Going to sit like this for awhile because of study and part time work this year, but first things to be done is replace the ignition switch as it refuses to run once key is released and install a proper choke, hates running cold. Then will start pulling it down and make a decision if I will be re shelling or restoring it.
