here i have some ca18 headgaskets only for sale before they go on trademe selling on here for 30 dolars each plus postage there are three off the top gasket and one off each the others
ok i got off the tools and on the phone and found out that the part number 11044-01Y00 is a twin cam gasket and all the others are single cam gaskets i have put the two gaskets together and there is only a couple water galleries different if you were scillfill with a punch set they can all be twin cam gaskets ...........
CA 18 Headgaskets
- Area Reps
- aka: shane
CA 18 Headgaskets
Re: CA 18 Headgaskets
twin cam ca18?
- Area Reps
- aka: shane
not sure man part numbers on them iff you wish to investigatedan1200sss wrote:twin cam ca18?
Check it out here.
CA18D
Piston diameter 83mm
http://www.gasgoo.com/showroom/capwauto ... 86714.html" onclick="window.open(this.href);return false;
CA18D
- Area Reps
- aka: shane
updated at the top page
