67 p411 bluebird
67 p411 bluebird
Just picked up this old girl for $200 with live plates. First project is to do the repairs and get it on the road. Then maybe a motor upgrade.
Datsun p411 bluebird
2014 Great Wall v240
Re: 67 p411 bluebird
Very nice...
Looks like a whole heap of work!
Please post lots of pictures.
Good Luck.
Good Luck.
At the moment, it needs a new left rear door/ skin and a new sill. I can fold up a sill at work easy enough, but the door skin is a little more than I am able to do myself. The front end has had a bad repair but I shouldn't have too much trouble fixing it. Going to split the b pillar as well as it will be easier to panel if I can get to the inside of it. The car itself is rust free apart from what you can see in the photo, but that is only surface. The motor runs but the timing and fuel are a mile out.
Don't you hate it when you go to use your welder and it is completely stuffed
yip sure do, and its worse if you have just got it back from lending it out and go to use it and its stuffed.
To bloody true2 doors wrote:yip sure do, and its worse if you have just got it back from lending it out and go to use it and its stuffed.
Don't tell the wife. Meant to be building her new living room in the bus. But she has taken her horse out, so I thought it would be a good tome to pull the datsun out of the shed and clean it up a little.
67 p411 bluebird
Haha. While the cats away the mice will play. Time better spent
Wal could make a lower section of door skin for that door yeah?
