Has anyone got a spare (happy to part with) bracket that is bolted to engine, that sits on the rubber mount for a12, B210 Type. It seems there are varying types and the one i have on the right side is incorrect for the B210 sedan.
The correct one has a curved/ angle shape to it.
A12 Engine Bracket R/h side
- twin120ys
- aka: Darrell or Cole
75 120y B210 Sedan
75 120y B210 SSS SEDAN (sold)
75 120y B210 SEDAN (sold)
Re: A12 Engine Bracket R/h side
I should have one, will dig them out
if Beaver cant help, I am bound to have one down here somewhere..........
I too have a box of mounts. I'd need a picture though. (Mine are from god only knows what)
- twin120ys
Here are some pictures of what it looks like if it helps anyone
75 120y B210 Sedan
Right, had a look through what I have. Cant help sorry, I have a pair off an early a12 from a 1200 wagon and they are slightly different. Hole spacing is different as well so wouldnt even bolt on to the block.
Kitch, can you help out?
I have one on an A14 that should be the same, if you are stuck I could split it.
- twin120ys
Thanks for looking Beaver.
Hope someone recognises it in the bottom of a box somewhere in the back of the shed
Will try for a randon before spliting a set classicdat, Cheers
75 120y B210 Sedan
