No ignition power.. im lost
C.Randall
Post by C.Randall »
My 140J has lost power to ignition and im lost when it come to electrics. Can anyone help me please. It would be fuse or relay right?
torqued
aka: Adam
Re: No ignition power.. im lost
Post by torqued »
Checked battery :tits:
C.Randall
Post by C.Randall »
Yes im not that lost. I have power to lights etc just not to ignition
nzbidzel
Post by nzbidzel »
Fuses and relays are a good start, checking the fuses is easy with a visual, relays a lil harder to check if still ok go with a youtube video to test them,
If however still at a lost then it could also be a failure in in the wiring itself alot harder to check. and can be a break in the wire without the sheathe broken needing a test of the wires itself with a multimeter, thats if its a wiring problem
describe what happens when you turn the key to start up:
turns over but wont start, no turn over at all, are your accessories working in on mode, when turning the key to start,
try putting a temp light circuit to light up when you turn to start and see if its not the ignition switch itself
C.Randall
Post by C.Randall »
I have pulled ignition switch out and tested for power, nothing turning switch does nothing. Fuse in foot well are all fine left aide of fuse box has no power right side does.
I think the supply may come through the key switch to the Fuse box, (I could be wrong). This would suggest that your wire to the switch is open circuited somewhere, ie before it gets to the key.
torqued
aka: Adam
Post by torqued »
If similar to 510,
This may help
Fuseable link?
C.Randall
Post by C.Randall »
Would HT lead stop any power getting to ignition? Not completing circut?
510BRE
Area Reps
aka: shane
Post by 510BRE »
yeah check ur fuseable link it looks jus like a normal wire and u can not c that its blown you will need to test it the fuse link is a short peice off wire with a plug on each end aprox eighty mm in length
it is normaly kept by the + battery terminal or close to the fuse box like 510s and i think in some cases with datsuns from the factory they tied a spare link up by the fuse box
if you need to replace ur fuse link you can get a replacement peice from auto electricans
