Yo guys, im thinking about doing a twin headlight conversion for my '81 sunny. How much of a mish would this be??
http://www.ebay.com/itm/DATSUN-Pick-Up- ... bf&vxp=mtr" onclick="window.open(this.href);return false;
I woud use this grille^^
http://www.ebay.com/itm/DATSUN-NISSAN-6 ... 9e&vxp=mtr" onclick="window.open(this.href);return false;
These headlights^^
http://www.ebay.com/itm/HEADLIGHT-BUCKE ... 67&vxp=mtr" onclick="window.open(this.href);return false;
And these brackets/buckets^^
What you guys reckon?? any advice?
B310 datsun sunny twin headlight conversion
Re: B310 datsun sunny twin headlight conversion
Your still going to need the mount that those buckets bolt to and you will most likely end having to weld tabs on the rad support panel to fit them. Also you might want to measure a 720 grille comapared to a 310 as it may be wider. It's all up to you and how bothered you can be doing it. Oh and you'd have to modify the wiring to suit twin head lights as well. If you did go through all that effort I would add beefier wiring with a relay with halogen bulbs. Not trying to put you off just being realistic.
Greg is bang on!
I'm sure you cold cut n shut the grill to suit.
Maybe try fit a 620 grill?
